I recently bought a Beocenter 9500. Everything "worked". However, things could be a lot better as the sound quality, in my opinion, was way short of what it could be. The sound was quite flat and lifeless when compared to my modded BM7000. So the Beocenter has become my latest upgrade project.
In essence I’ve done a capacitor and opamp upgrade. Here is what I’ve done to date:
Inside the Beocenter 9500 after upgrade.
1- Preamp/Source Select; Signal path caps replaced with WIMA (red caps). All other electrolytics replaced with Nichicon PW. Replaced LF353 opamp with OPA2134
2- Preamp/ Tone control; Signal path caps replaced with WIMA. All other electrolytics replaced with Nichicon PW. Replaced the two 4558 opamps with OPA2134
3- Amp/PSU; Signal path caps replaced with WIMA. All other electrolytics replaced with Nichicon PW.
4- CD Decoder; Replaced all caps with Nichicon PW except for C2366 and C2367, these were replaced with Nichicon Muse KZ
5- CD Servo; C2159 replaced with WIMA , C2103 with 47uF Vishay BC axial (in a white plastic case as opposed to the blue metal can; All other electrolytics replaced with Nichicon PW.
6- CPU/IR; All electrolytics replaced with Nichicon PW.
Can now report that the sound quality is much improved, particularly in the higher frequencies which are much clearer, detailed and have a "sparkle" to them.
I’ve yet to replace the following large snap-in style caps on board 62 in the PSU section:
C5 & C6 – 6800uF
C12 – 2200uF
C17 – 10000uF
I haven’t found any suitable replacements for these. Physical size and pin configuration is important here due to space restrictions and the plastic that clamps around the caps when mounted. Anyone replaced these caps?
At this stage I’ve left the tuner and tape boards as they are.
Also replaced were the three belts in the tape head unit and the two driving the tape/ CD covers.
I’ve also remounted the two top glass panels as the original double sided tape had failed. There has been much discussion on this forum on whether to use tape or glue (see this thread http://forum.beoworld.org/forums/t/37232.aspx). In the end I opted for glue. Main reason for this was I didn’t want the glass to stick up too high above from the edge of the frame due to the thickness of the tape.
