Hi all,
My Beocenter 9300 wich is ten years old doesn't answer to remote commands since recently.
I though it was the remote, but i changed the batteries and it was the same.
Manually or by link, the beocenter works well, only by remote it doen't work.
What can be the problem ?
Thanks for your help
Zazou
