Hi!
I just received today the B&O 5pin Aux to iPod connector that i'd like to use for my Beocenter 9300 and iPod Touch.
I'm just wondering cause i just tested it now and the sound only comes from one side (right side). The sound integrity is excellent however but it's only coming from one speaker. I already tried other players (another mp3 player and my trusty laptop) and still the same thing. I also tried connecting to the Tape2 connection (instead of Aux) and still the same.
I opened up the Neutrik connector as well as the 3.5mm jack to see if there are loose connections but can't seem to find any. I'd just like to clarify if the connections are right (everybody makes mistakes when it comes to small wires) :)
As for Neutrik 5pin connector, the white wire is on 3, the red wire on 5 and the ground wire on 2. As for the 3.5mm jack for the ipod, the white is on center and the red a bit outside, ground wire being on outermost.
Please clarify. I'm just hoping it's a small misconnected wire and i can just resolder. Resending the cable to the seller wouldn't be feasible (cause I'm here in the Philippines and the shipping costs would make it prohibitive to send back to the US).
Thanks and looking forward to anybody's help and reply.
~ mans
