The cd doesn't spin after accepting a disk and the door then reopens. I've tried a very light clean of the laser lens to no avail. Are there any common faults or simple checks I could do with a meter for example before admitting defeat and taking it to the local store for a mechanism change out? 9300 is a type 2520, SW1.3, serial number 11684776.
Hope someone can help, Regards, Clive
Hello Clive
Well.. no offence, but the guys in here are really crazy about changing caps. I had a similar problem with a B&O overture. It had a CMD12ind drive mechanism.
I was also told to change all the caps, i tried to find some datasheets on the CMD12ind mechanism, and found out that buying all the caps with the correct specifications seemed to bee very complex.
On the other hand i found in the service manual, that when the CD does not spin, the laser isnt able to find focus.
I turned the overture into service mode, and could read exactly that error "focus error"
I tried to disassemble and clean the laser unit with instructions from guides online, but with no success.
I wanted to try to buy a new one, unfortunately the laser unit was no longer avavible (it was actually avavible when i brought the defective Overture) :)
Nevertheless i searched ebay, and found a seller in China (gobuyjudy[AT]hotmail.com)
, who asked me to send a picture of the laser unit. I did, and i send him ~30$. I did not really hear from him afterwards but
14 days after, i recived what seems to be a quite good quality part. I replaced it with the broken one, and greased carefully the moving parts, and it has ben playing every day since :)
You should know there is several different versions of the laser unit and the cd mechanism. But mine were a CMD12ind and the laser unit had the IC mounted TDA1302T
I actually think i could have bought this one. It is similar to the one i got, and even cheaper:
