Sami,
Yes, a kit is available for this version.
You have a PM (check your inbox).
Sami,
Now those capasitors are changed... but still problems.
1) WILL SPIN, TRY TO FOCUS, DISPLAYS TRACK NUMBERS, DOESNT PLAY
2) AS ABOVE, BUT DOESNT DISPLAY NUMBERS
3) TRYS TO SPIN, TRY FOCUS, THEN THEN DOOR OPENS READY FOR ME TO TAKE THE CD OUT.
Maybe there is also problem like here:
http://forum.beoworld.org/forums/p/32337/263698.aspx#263698
Any ideas?
Any ideas?
Have you tried cleaning the optics? They may have dusted up a bit when you're tinkering around in the unit.
Could be cracked solder joints at the voltage regulator(s)
with the small cooling fins at the bottom center board next to the CD deck.
Could you show it in photo or diagram.
.sami
In CD-test mode BEO gives code F.2 for test 2 (focus moving and some light in laser) and F.4 for test 4 ( CD rotate but no radial searching). All other tests working.
.sami
Have you got the thin ribbon cable to the laser block correctly seated in the connector ?
- And undamaged ?
Hello,
Almost year is past and now I have again time to start to try fix my BC.
I'm still figthing with this problem...
All capasitors are changed, thanks for Martin. Now I did resolder them and CD was working fine..... but then again back to the start.
Mayby there is somewhere some other cold solder...
