Normal
0
21
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
I have this
same problem in Beocenter 9000. CD just spins couple of seconds and then opens
the door.
How many
capacitors there is to change? And what are the values of the capacitors?
I work with
electronics so I should have the skills to do job. If I just know which
capacitors to work with.
Best
regards
Pete
Normal
0
21
false
false
false
font-size:10.0pt;
Normal
0
21
false
false
false
font-size:10.0pt;
