Beocenter 8500 power relay needed
Hi all,
After having repaired many faults in the power circuit and replacing the "normal parts" (mute relay, backup battery) the only component left broken is the power relay.
I haven't seen them being broken a lot, but probably due to a failure in the 7V circuit the relay coil burnt through (or the other way around).
It's the 4PDT 12 + 2 pins relay (RL1 on PCB60).
Tried already many sources, but it seems this relay is becoming obsolete / old fashioned etc... Not in stock any more (tried Tyco/Axicom; Farnell; RS components; Siemens and Panasonic).
So any one here has such a relay by any chance (or a good source/hint?).
Thanks a lot!
Can you post pictures - with the top/side view, and the bottom pin views?
Electronics Technician in Jerusalem Israel. B&O fan for over 50 years.
Found some old stock at the local electronics dealer. Problem solved.
