Customer Service, Bang & Olufsen [1/21/2009 12:57:00 PMCET]
[#4178] The chatroom is now open
Customer Service, Bang & Olufsen [1/14/2009 2:01:00 PMCET]
[#4177] The chat room will close down in a few minutes
KALYAN BANERJEE, India [1/14/2009 1:51:00 PM CET]
[#4176] TNX, I AM CLOSING THE CHAT. WILL WAIT FOR UR MAIL. IF QUARY PL MAIL OR PH # +919836544755
Customer Service, Bang & Olufsen [1/14/2009 1:50:00 PMCET]
[#4175] Answer to post #4174
Thank you for this information
KALYAN BANERJEE, India [1/14/2009 1:49:00 PM CET]
[#4174] BEOCENTER 2 AUDIO MASTER WITH OUTSTANDING FM TUNER WITH CD DRIVE AND OPTIONAL DVD
Customer Service, Bang & Olufsen [1/14/2009 1:47:00 PMCET]
[#4173] Answer to post #4172
Do you have the type number for the BeoCenter 2?
KALYAN BANERJEE, India [1/14/2009 1:46:00 PM CET]
[#4172] TNX, PL SEND THE MAIL USERGUIDE FOR BOTH BeoCenter 2 and BeoLab 3 AT hac_kol@yahoo.com. BY, GOOD DAY
Customer Service, Bang & Olufsen [1/14/2009 1:45:00 PMCET]
[#4171] Answer to post #4170
I regret that you are not satisfied with quality of my answers.
KALYAN BANERJEE, India [1/14/2009 1:42:00 PM CET]
[#4170] YES, U CAN SEND IT USERGUIDE FOR BOTH. UR RESPOND QLTY IS NOT UPTO THE MARK AS PER B& O . I AM NOT AT ALL SATISFY
Customer Service, Bang & Olufsen [1/14/2009 1:41:00 PMCET]
[#4169] Answer to post #4168
Is it the user guide for BeoCenter 2 and BeoLab 3 you are asking for? I can send it by email to you.
KALYAN BANERJEE, India [1/14/2009 1:40:00 PM CET]
[#4168] THANKS FOR SOFT HEARING. CAN U SEND ME MAIL FOR 'BEOCENTER 2 WITH BEOLAB 3. DRW ROOM IS 600 SQ FT KALYAN
Customer Service, Bang & Olufsen [1/14/2009 1:38:00 PMCET]
[#4167] Answer to post #4166
This was an answer for another request
KALYAN BANERJEE, India [1/14/2009 1:37:00 PM CET]
[#4166] WHICH WEBSITE SHOULD I WRITE
Customer Service, Bang & Olufsen [1/14/2009 1:36:00 PMCET]
[#4165] Answer to post #4161
May I ask you to write to us through the website and "Contact us" as I would have to investigate this further.
KALYAN BANERJEE, India [1/14/2009 1:36:00 PM CET]
[#4164] THANKS FOR SERENETA. I WANT TO BUY 'BEOCENTER 2 WITH BEOLAB 3. IS IT COMPITABLE? MY DRW ROOM IS 600 SQ FT
Customer Service, Bang & Olufsen [1/14/2009 1:34:00 PMCET]
[#4163] Answer to post #4162
The dealer always has to check if a fault is covered by the warranty. But I would believe that it is.
KALYAN BANERJEE, India [1/14/2009 1:32:00 PM CET]
[#4162] I WANT TO MEAN YOU ARE NOT REGRET AT ALL FOR THE FAULT, YOU R TELLING IT CAN HAPPEN ANY TIME. IT HAS ONLY ONE VISIBLE BUTTON & 'OK' BUTTON U HV 2 USE MAXIMUM TIME
Gerd Gerasch, Germany [1/14/2009 1:31:00 PM CET]
[#4161] How must connect "Beovision 8-32" with "Beocord V6000" and "DVD2". I want to copy a film from Camcorder to V 6000. Then from the V 6000 to the hardware of DVD2, after this to get a DVD. Must I program also the BEO4, when yes, what I must do?
Customer Service, Bang & Olufsen [1/14/2009 1:30:00 PMCET]
[#4160] Answer to post #4159
I am not sure that I understand your question?
KALYAN BANERJEE, India [1/14/2009 1:29:00 PM CET]
[#4159] ABOUT SERENATA I WANT TO KNOW B&O HAS NO OBLIGATION ABOUT THEIR PRODUCT GUARENTEE. JUST WRITE YES OR NO
Customer Service, Bang & Olufsen [1/14/2009 1:28:00 PMCET]
[#4158] Answer to post #4157
I regret to hear that you have not been able to use the sw. The dealer will have to check if it is covered by the guarantee.
KALYAN BANERJEE, India [1/14/2009 1:26:00 PM CET]
[#4157] I HAVE ALREADY TRIED OUT, BUT COULD NOT ABLE TO DO. SHOULD I PAY ANYTHING FOR REPAIR CHARGE
Customer Service, Bang & Olufsen [1/14/2009 1:24:00 PMCET]
[#4156] You have to use the software from the cd you received at purchased.
KALYAN BANERJEE, India [1/14/2009 1:23:00 PM CET]
[#4155] HOW CAN I TRANSFER DATA ( PHONE BOOK, MUSIC, VIDEO, SMS ) IN COMPUTER. I WANT A BACKUP BEFOR HANDOVER
Customer Service, Bang & Olufsen [1/14/2009 1:21:00 PMCET]
[#4154] Answer to post #4152
We cannot see why this should happen again since it is not a known error
KALYAN BANERJEE, India [1/14/2009 1:21:00 PM CET]
[#4153] REPAIR IS FREE OF COST. WHAT IS THE VALUE GUARENTEE.
KALYAN BANERJEE, India [1/14/2009 1:20:00 PM CET]
[#4152] IF I WILL REPAIR THROUGH YOUR DEALER, IS THERE ANY CHANCE OF REPET PROBLEM
Customer Service, Bang & Olufsen [1/14/2009 1:19:00 PMCET]
[#4151] Answer to post #4148
it is probably not the first complaint, but there is no general problem with the OK button
Christina, Denmark [1/14/2009 1:18:00 PM CET]
[#4150] K - thx
Customer Service, Bang & Olufsen [1/14/2009 1:17:00 PMCET]
[#4149] Answer to post #4146
Please write in English in the chat room
KALYAN BANERJEE, India [1/14/2009 1:17:00 PM CET]
[#4148] SO IT IS A FIRST COMPLAIN IN SERENATA IN THE EARTH.
[#4147] Answer to post #4144
No it very difficult to estimate the life span of a battery since it depends on the usage.
Gerd Gerasch, Germany [1/14/2009 1:16:00 PM CET]
[#4146] Wie müssen ein Videogerät "Beocard V6000" mit einem FS-Gerät "Beovision 8-32" und einem DVD2-Player angeschlossen werden.Ich möchte von einem Camcorder Filme auf den V6000 überspielen.Danach vom V6000 auf die Festplatte des DVD2 kopieren um eine DVD brennen zu können.Wie muß weiterhin die Fernbedienung "Beo4" programmiert werden?
Customer Service, Bang & Olufsen [1/14/2009 1:16:00 PMCET]
[#4145] Answer to post #4143
We are not familiar with this particular problem with the Serenata.
Christina, Denmark [1/14/2009 1:16:00 PM CET]
[#4144] We have two chargers so it must be the batteries then. Is there a limit on how it normally works?
KALYAN BANERJEE, India [1/14/2009 1:15:00 PM CET]
[#4143] I WILL HAND OVER IT B & O DEALER. I WANT TO KNOW IS IT A STANDARD PROBLEM. IF IT IS A STANDARD PROBLEM THEN WHY I SPEND MONEY IN B & O? PLEASE CLARIFY.
Customer Service, Bang & Olufsen [1/14/2009 1:14:00 PMCET]
[#4142] Answer to post #4140
Okay. It can either be the battery or the power supply for the charger that is defective. You will have to bring the telephone to the nearest Bang & Olufsen shop for repair.
Customer Service, Bang & Olufsen [1/14/2009 1:13:00 PMCET]
[#4141] Answer to post #4139
We are sorry to hear that you have problems with the Serenata. You will have to go to the dealer in HK for repair help of the Serenata
Christina, Denmark [1/14/2009 1:12:00 PM CET]
[#4140] They just shut down...
KALYAN BANERJEE, India [1/14/2009 1:12:00 PM CET]
[#4139] I BOUGHT SERENETA MOBILE FROM YOUR HK DEALER. THE PROBLEM WITH OK BUTTON. OK BUTTON IS NOT WORKING ATAL. WHAT TO DO, IS IT A STANDARD PROBLEM. SEEKING YOUR HELP.
Customer Service, Bang & Olufsen [1/14/2009 1:12:00 PMCET]
[#4138] Answer to post #4137
Do they shut down or show low battery
Christina, Denmark [1/14/2009 1:11:00 PM CET]
[#4137] Ok. We have 2 phones - about 5 years old - but it seems as though they aren't functioning right anymore. If they have been out of the station for more than one hour, they aren't working - they simply seem as though they are out of battery. That can't be right...?
Customer Service, Bang & Olufsen [1/14/2009 1:08:00 PMCET]
[#4136] Answer to post #4135
Yes but in English please.
Christina, Denmark [1/14/2009 1:06:00 PM CET]
[#4135] Spørgsmål omkring Beocom 6000, kan de besvares her?
Customer Service, Bang & Olufsen [1/14/2009 1:02:00 PMCET]
[#4134] The chat room is now open
Gerd Gerasch, Germany [1/7/2009 2:03:00 PM CET]
[#4133] Geräte: FS Beovision8-32Fernbed.Beo4DVD 2 und Videoger.V6000. Ich möchte von einem Camcorder einen Film auf den Beocard V 6000 überspielen.Danach vom V 6000 auf die Festplatte des DVD 2 überspielen um eine DVD brennen zu können.Wie muß der DVD2 u.die Beo4 programmiert werden?
Customer Service, Bang & Olufsen [1/7/2009 1:30:00 PMCET]
[#4132] Answer to post #4131
We have to keep the language in English in the chatroom, and I therefore answer in English. BeoLab 6000 has a built-in amplifier, and can be used with other products if the product you connect it to has a socalled volume regulated line output.
Uwe Braun, Germany [1/7/2009 1:22:00 PM CET]
[#4131] Hi,benötige ich einen besonderen fremden Verstärker (z.B. von Panasonic), wenn ich diesen mit meinen Beolab 6000 Lautsprechern verbinde? Gibt es etwas Spezielles zu beachten, weil es ja Aktiv-Lautsprecher sind?
Customer Service, Bang & Olufsen [1/7/2009 1:01:00 PMCET]
[#4130] The chatroom is open. We wish you all a happy new year.
Customer Service, Bang & Olufsen [12/17/2008 2:10:00 PMCET]
[#4129] The chatroom will now close
