xxx
Coolskin,Netherlands [2/13/2008 1:39:00 PM CET]
[#3566] Canthe BEO4 remote be configured like the A9 keychain? The keychain remote canswitch all, including lights, off with the touch of 1 button.
Coolskin,Netherlands [2/13/2008 1:37:00 PM CET]
[#3565]Sorry double post: 3561, 3564.
Coolskin,Netherlands [2/13/2008 1:35:00 PM CET]
[#3564]@Guido, press simultatiously RED DOT and LIST. Your system will shut down inthe process. You see "ADD?". Press GO. Press LIST until you see"PC". Press GO. Now PC is in you LIST menu. Good luck.
CustomerService, Bang & Olufsen [2/13/2008 1:34:00 PMCET]
[#3563]Answer to post #3558The modelsare Samsung SPH 700 & 800. Furthermore also SIM2 C3X
Guido,Germany [2/13/2008 1:32:00 PM CET]
[#3562] yesi see the button DTV
CustomerService, Bang & Olufsen [2/13/2008 1:32:00 PMCET]
[#3561]Answer to post #3559You need topress the standby buttom and LIST at the same time and then you press GO untilit says ADD in the display and then you press LIST until you PC in the display,and save this.
Coolskin,Netherlands [2/13/2008 1:31:00 PM CET]
[#3560]@Guido, your BEO4 model should have a DTV button... Does it?
Guido,Germany [2/13/2008 1:30:00 PM CET]
[#3559] ihave the beo4 button list "format" list "stand" list"speaker" list "p-and-p" list "AV" in theinstructions is speak for "PC"
Coolskin,Netherlands [2/13/2008 1:30:00 PM CET]
[#3558] @CS,#3556. Could you point out which models if you please?
Coolskin,Netherlands [2/13/2008 1:29:00 PM CET]
[#3557] @CS,thanks for the Power link MKIII cable suggestion. That's usefull information.
CustomerService, Bang & Olufsen [2/13/2008 1:29:00 PMCET]
[#3556]Answer to post #3553It ispossible to connect a projector, but only two different models from Samsung aresupported by the BeoVision 7
Coolskin,Netherlands [2/13/2008 1:27:00 PM CET]
[#3555]@Guido, do you use the most recent BEO4? I think only this BEO4 model has"PC" under LINK.
CustomerService, Bang & Olufsen [2/13/2008 1:26:00 PMCET]
[#3554]Answer to post #3551You need toadd the PC in the LIST of your Beo4. You will find the instuction for this inyour user guide.
Coolskin,Netherlands [2/13/2008 1:26:00 PM CET]
[#3553] Ihave a prehistoric BV7 (version 2004) and like to hook up a beamer for fun.Just to see if this is something I like. If so I could investigate how to setup such kind of setup. Is my (old) BV7 equiped to handle the beamer?
CustomerService, Bang & Olufsen [2/13/2008 1:25:00 PMCET]
[#3552]Answer to post #3549As regardsthe BeoLab 3 we are not aware of any problems when you use the Power link MKIIIcables
Guido,Germany [2/13/2008 1:24:00 PM CET]
[#3551] iwant connect a pc to my TV, in av4 i have registered pc but on the remotecontroll i have not a point "PC" by AV no funktion !!
CustomerService, Bang & Olufsen [2/13/2008 1:22:00 PMCET]
[#3550]Answer to post #3547Please writein English
Coolskin,Netherlands [2/13/2008 1:22:00 PM CET]
[#3549] Anew year and new wishes... I like to get my hands on a set Beolab 3 speakers.On a B&O fansite (http://forum.beoworld.org) I have read that there couldbe issues with these speakers. A humming noise at low volumes. Is this issuesolved now?
Guido,Germany [2/13/2008 1:22:00 PM CET]
[#3548]Brauche Hilfe bei einem B&O Fernseher
niko, Sweden[2/13/2008 1:22:00 PM CET]
[#3547] Hejjeg har et spørgsmål, vedr. BeoCom 6000 tlf. CustomerService, Bang & Olufsen [2/13/2008 1:13:00 PMCET]
[#3546] Answerto post #3545Welcome tothe chatroom
Coolskin,Netherlands [2/13/2008 1:12:00 PM CET]
[#3545] Hi,nice to see you again.
CustomerService, Bang & Olufsen [2/13/2008 1:00:00 PMCET]
[#3544] Thechatroom is now open
CustomerService, Bang & Olufsen [2/6/2008 2:00:00 PMCET]
[#3543] Thechatroom is now closing.
CustomerService, Bang & Olufsen [2/6/2008 1:22:00 PMCET]
[#3542]Answer to post #3541There is apossibility if you ask your dealer to add it to the list of supported DVDplayers.
dieter,Italy [2/6/2008 1:20:00 PM CET]
[#3541] butis there a possibility to use my beo5 with my own dvdplayer (kiss vr558 300?)or its impossible?
dieter,Italy [2/6/2008 1:18:00 PM CET]
[#3540] ok... i will ask him when he returns from his holyday
[#3539] :-(
CustomerService, Bang & Olufsen [2/6/2008 1:17:00 PMCET]
[#3538]Answer to post #3535No, I cannotsend this to you. Please contact your dealer about this. Only the dealer canprogramme Beo5.
dieter,Italy [2/6/2008 1:16:00 PM CET]
[#3537] thetf5000pvr is on the beovision7 ... but not on the programm "beoconfigurations tool"
CustomerService, Bang & Olufsen [2/6/2008 1:15:00 PMCET]
[#3536]Answer to post #3533The Topfield- TF5000PVR is on the list of supported digital receivers. If you do not see itin the menu, an authorized dealer can update the STB-Controller in yourBeoVision 7.
dieter,Italy [2/6/2008 1:15:00 PM CET]
[#3535] ihave an idea ... can you send me the *.xml file to put it on my beo5? i havethe beovision7 40" the beosound 3200 beolab 8000 and the beolab2 (than thekiss vr-558 300 and the topfield tf5000pvr)
CustomerService, Bang & Olufsen [2/6/2008 1:12:00 PMCET]
[#3534]Answer to post #3527None of theDVD players from Kiss are on the list. However, you can contact an authorizedBang & Olufsen dealer and ask him to add your the Kiss model to the list,but this is something you will have to pay for.
dieter,Italy [2/6/2008 1:10:00 PM CET]
[#3533] buton the program "beo configurations tool" there is not present thetf5000pvr. (on the menu of the television it is present)
dieter,Italy [2/6/2008 1:08:00 PM CET]
[#3532] +another problem ... i have the satreciver topfield "tf5000pvr"
CustomerService, Bang & Olufsen [2/6/2008 1:07:00 PMCET]
[#3531]Answer to post #3530Okay, I willcheck it.
dieter,Italy [2/6/2008 1:07:00 PM CET]
[#3530] kissvr-558 300
[#3529]http://www.kiss-technology.com/
CustomerService, Bang & Olufsen [2/6/2008 1:06:00 PMCET]
[#3528]Answer to post #3527I cannot saywhether the Kiss DVD player can be operated by your Beo5. First I need to knowthe exact model name of your Kiss DVD player.
dieter,Italy [2/6/2008 1:04:00 PM CET]
[#3527] cani use the beo5 for my dvdplayer?
[#3526] ihave a "kiss" dvd player
dieter,Italy [2/6/2008 1:03:00 PM CET]
[#3525] ibought the beovision7 with the beo5 ...
CustomerService, Bang & Olufsen [2/6/2008 1:03:00 PMCET]
[#3524]Answer to post #3522The chatroomlanguage is strictly english.
CustomerService, Bang & Olufsen [2/6/2008 1:02:00 PMCET]
[#3523]Answer to post #3521Hi, andwelcome to the chat.
dieter,Italy [2/6/2008 1:02:00 PM CET]
[#3522]someone that speak german?
[#3521] hi
CustomerService, Bang & Olufsen [2/6/2008 1:00:00 PMCET]
[#3520] Thechatroom is now open.
CustomerService, Bang & Olufsen [1/30/2008 2:16:00 PMCET]
[#3519] Thechatroom is now closing.
[#3518]Answer to post #3516We must keepthe language in English in the chatroom. In order to obtain a Mastercode forBeoSound 1 you need to contact an authorised dealer. You need to show some IDand give them a postal address. Then the Mastercode will be sent to you bypost. I doubt that they will be able to help with the PIN-code.
CustomerService, Bang & Olufsen [1/30/2008 2:13:00 PMCET]
[#3517]Answer to post #3515I am sorryit took a while to come back to you. But I tried to find a BeoSound 1 on astand. I can see that there is a small hole in the rear at the back of theplate on the stand. But I cannot see that there is a matching hole in BeoSound1. I cannot say what the holes you mention might be for.
MartinNielsen, Denmark [1/30/2008 2:08:00 PM CET]
[#3516] HejJeg har et spørgsmål. Jeg har fundet et ødelagt Beosound1 i en kontainer. Nuhar jeg efter noget tid fået det til at virke på trods at et lidt smadretkabinet. Men jeg har et problem da det er låst med en kode. Jeg snakkede medjeres en af jeres forretninger der forslog mig at kontakte jer idag på dennechat med serinummeret og få en masterkode.
Frank vanEkeren, United Kingdom [1/30/2008 2:05:00 PM CET]
[#3515]there is one whole in the stand itself and one in the sytem, at the sameplace.....must be there for a reason
CustomerService, Bang & Olufsen [1/30/2008 2:04:00 PMCET]
[#3514]Answer to post #3513I am notcertain which holes you refer to? but there are no holes for a fixing screw.
Frank vanEkeren, United Kingdom [1/30/2008 2:03:00 PM CET]
[#3513]thanks for your message. Not great that it can not be fixed. What are thoseholes for?
CustomerService, Bang & Olufsen [1/30/2008 2:02:00 PMCET]
[#3512] Thechatroom is now closing.
CustomerService, Bang & Olufsen [1/30/2008 2:00:00 PMCET]
[#3511]Answer to post #3510Yes, it iscorrect that BeoSound 1 is not fixed to the floorstand, but is placed over the4 pins. There is no larger pin or screw for this. We have not experiencedproblems with BeoSound 1 falling off the stand.
Frank vanEkeren, United Kingdom [1/30/2008 1:54:00 PM CET]
[#3510] Isit correct that the Beosound 1 is not actually fixed to the floorstand, butjust placed loosily on the stand on 4 tiny pins? There seems to be an extrahole in the stand and acorresponding hole in the system, which suggest that alarge screw or pin might fit to secure the system to the stand. No suchpin/screw was delivered however. I would find it very odd if the system can notbe fixed to the stand as it quite easily could fall of. grateful for yourresponse, thanks, Frank van Ekeren
Thomas,Denmark [1/30/2008 1:50:00 PM CET]
[#3509] Youranswer is noted
CustomerService, Bang & Olufsen [1/30/2008 1:48:00 PMCET]
[#3508] Icannot help with a solution based on your description. It is the dealer who cancome up with a solution. But as your telephone is 3,5 years old and has had noprevious problems, I am quite certain that we cannot offer to repair thetelephone free of charge or at a reduced price. But in order to find outwhether the telephone is in fact defective, it will be necessary for thedealer/workshop to have a look at it.
Thomas,Denmark [1/30/2008 1:45:00 PM CET]
[#3507] Comeup with a possible solution or suggestion to solving the problem, this cannotbe the first time someone experienced this problem.
CustomerService, Bang & Olufsen [1/30/2008 1:44:00 PMCET]
[#3506]Answer to post #3505I must askyou to contact a dealer, as I am unable to help from a distance. I am notcertain what you would like me to do through the chat or e-mail?
Thomas,Denmark [1/30/2008 1:42:00 PM CET]
[#3505] Sodo I. But also I expect more support from you, when this type of failureshappens. We had 2 reasons for choosing this products design and quality, andfor the last I do expect more than 3,5 years life.
CustomerService, Bang & Olufsen [1/30/2008 1:39:00 PMCET]
[#3504]Answer to post #3503I am sorryif the telephone is defective. But this can happen with Bang & Olufsenproducts also. We understand that you are disappointed if the telephone isdefective and requires a repair. But we must consider this to be an unfortunatebut accidental failure, which may occur in any electronic equipment.
Thomas,Denmark [1/30/2008 1:36:00 PM CET]
[#3503] Iwas just under the - apparently - wrong impression that a service chat wasactually able to come up with some suggestions. Going to a dealer with a phonethat is 3,5 years old, and therefore outside national guarantee will be asignificant write off. I dont'get surprised if a cheap phone breaks down thatsoon, but not a B&O product.
CustomerService, Bang & Olufsen [1/30/2008 1:32:00 PMCET]
[#3502]Answer to post #3501I am sorrythat Fona asked you to call us to get help. But it is not possible for us totell from a distance what may be the reason for the problem. This is why I haveto refer you back to a dealer. If Fona cannot help, I suggest you contact adedicated Bang & Olufsen dealer to get help. You can find dealer addresseson our website, if required.
Thomas,Denmark [1/30/2008 1:29:00 PM CET]
[#3501] Icall you for help, yesterday the official B&O dealer FONA in Aalborg toldme to contact you. Seems to me that responsibility is just being pushed on. Ihave a technical issue with a high profiled and expe3nsive product and franklyI expect more service from B&O than when calling a low budget company.
parkere,Nigeria [1/30/2008 1:21:00 PM CET]
[#3500]thanx !
CustomerService, Bang & Olufsen [1/30/2008 1:20:00 PMCET]
[#3499]Answer to post #3498I cannothelp you with these details from here. But please follow the link I just gave,you and maybe write to the responsible department through this. There are anumber of requirements which have to be fulfilled in order to become a dealer.
parkere,Nigeria [1/30/2008 1:18:00 PM CET]
[#3498] whatdoes it take to be a dealer ?
CustomerService, Bang & Olufsen [1/30/2008 1:16:00 PMCET]
[#3497]Answer to post #3494We only sellour products to authorised dealers, so in order to buy from here you need tobecome an authorised dealer. You need to contact us through the website:http://www.bang-olufsen.com/page.asp?id=176 - Please note that I cannot promisethat you will become an authorised dealer.
parkere,Nigeria [1/30/2008 1:15:00 PM CET]
[#3496] imean making me agent for ur product
CustomerService, Bang & Olufsen [1/30/2008 1:14:00 PMCET]
[#3495]Answer to post #3492We must keepthe language in English in the chatroom. If you experience problems with thecharging of the phone the telephone may be defective, or the battery may needto be replaced. Please contact your dealer in order to obtain help.
Published by Coolskin
