Attyca 1 project
My attyca 1 is in need of renovation. The bench has a scratched edge. Has anyone tried to restoring an attyca bench with a scratched edge? Do you have any good ideas to restore the edge?
I'm thinking of putting an angled sheet of brushed aluminum or stainless steel.
Attyca 1 project
I think a filler, sanding and repainting might do the job.
Hi Blackrix,
Thank you for your responding.
Yes, that's probably a good idea. How about my suggestion?
[quote user="Krona"]
Hi Blackrix,
[/quote]
To get a Aluminu angle look good, you will have to get it level to the surface, that means, machine the surface down where you want to place it, if you dont have the tools for it, imposible, if you have them, difficault. One mis and you will have to do the whole front/edge.
Best and easiest is filler, sand, mask of, spray paint, sand very fine, spray paint, and one time more if wanted.
Instead of filler, you can mix wood glue with 50 % wood dust (fine saw dust) it will give a harder edge.
The key to the finish is sanding, sanding, sanding, finer, finer, finer
Retired Printing machine technician Restored various 1960-70 items Rock and Roll music Collecting Vinyl Restored Jukebox Wurlitzer 1050
I think with an angled piece of stainless steel or aluminium it will be harder to get a nice fit than the use of a filler and sandpaper. If you take some time for it you will get a nice result. And if you go to a good store they can probably supply you with the right colour paint in a spraycan.
What about stripping of the old veneer from the sides and aplying a new white thick fineer, plus having a paint job!
That is a way to get it done, but I think that might be the hard way.
There were many good suggestions. You seem to be on the same track. Now I have many good suggestions to consider. The bench will be renovated this summer and then the bench will have a different color. It will be painted in black.
Thanks 🙂
You can use a filler (epoxy) from the car industry, it will get very hard and you can sand it till the surface is smooth.  Normal filler will not hold.  When you use the colour black, it needs a real flat surface with out dents etc etc.  On black you will see every scratch/dent because of the light refelection.
Do you have considered a metalic silver finish?
Thanks for the tip. Epoxy is probably a good choice. I will paint the bench, as a suggestion, in two colors. Black and dark gray. Silver Metallic's not my favorite color.
