Verison Fios with BS1?
Is anyone using Verizon's Fios TV service? Can you control the STB's with the Beosystem 1? I currently have DirecTV have no problems, but I was thinking of changing out. I fear I will go back to using two remotes.
In Northern Virginia, Verizon is using boxes built by Scientific Atlanta, and the ir codes are the same as the 3xxxHD series Cable boxes.
Russ
I'm in New York, Verizon uses Motorola Boxes (Motorola 7216)
Does anyone know from which SW version BS1 can operate these boxes?
