Resetting Beocom Base?
Help please,
I am trying to reset my Beocom 6000 Base back to factory settings (no worries of losing any data). I did find a post instructing to press 9#9#9* INT   but I am not sure what "INT" stands for, since I can't find any buttons for it.
Thanks.
Beodoc
INT = Intercom (at least on my Beocom 1... which I always thought was the same as a Beocom 6000)
I thought so but didn't find it in a hurry. I will check it out tonight.
Thanks.
I am trying to reset my base as well but I keep getting that I have too many handset registered to the base.  How do I clear the base?????
THANX
the command 9#9#9* INT doesn't do anything. Is this the correct sequence to fully reset the base?
the correct code to reset the base to factory settings is:
Dot 70008 and then press enter (thanks to Beo Care center)
Beodoc
