I was dusting my Beomaster 2400 when I noticed what appeared to be a slight bubble in the control surface. A little rubbing and plastic began peeling off. A bit more rubbing and a LOT more plastic peeled off. Eventually with an hour of rubbing the entire surface peeled.
It was almost as if the protective layer often applied to plastic surfaces was never removed and was now coming off in small sections.
Has anyone ever encountered something like this? I am concerned that the plastic is actually delaminating with age.
Jeff
