Parts for a beocenter 9500
I cant find any sorse for parts and theres only one B&O store in the state.  Help!!!!   I'm looking for the drive belts for the door moters, the plastic channels that hold the glass top & bottem, a clip for the prop rod and a new battery.
P.S.  I had problums with both doors not oppening so I oppend it and found 3 of the 4 strings off.  I got all 3 back on (a big pain in the butt) the tape door works well but the cd door will only work when in the servise position.  It seems stiff and slow wen it does oppen and some times wont oppen all the way.   Any Ideas?
Mike
where in the states are you located?
i have had great service from Benny @ 770-642-6259 (atlanta, ga)...
he was recommeded by the b&o store there as he is the regional repairer.
he was able to source what i needed for my 9300.
highly recommended...
also... w/ regards to the sticky door...
make sure that the tabs that slide in the rails are straight and true! they tend to get out of whack after force has been applied to them. they are relatively delicate -a little warm water and gentle coaxing should re-align them -that fixed mine.
I'm in Maryland.  I'm not what tabs your refering to but I think they are ok.  I'm pretty shure I dont want to take the strings off again if I dont absolutly haft to. NOT A FUN JOB.
Thanks guys
Mike
3 good sources for B&O parts and repair in the USA:
Paul - Atlantic Systems MA  781-826-8760
Larry - Approved Audio CT  860-567-5801 repair@approvedaudioservice.com
Chris Lewis - Pyramid Audio TX  512-458-8292  tech@pyramid-audio.com
All 3 are recommended highly
Electronics Technician in Jerusalem Israel. B&O fan for over 50 years.
