Modding B&O speakers?
Anyone ever thought -or tried out modding any of their speakers? I have these Beovox S45-2 ones and I do like the imaging but feel like the tweeter driver could be replaced with a better one.
I'm not averse to modding speakers. However, you might want to consider restoring the speakers to original condition before trying modifications. Verify that the capacitors in the crossover are good, the surrounds are in good condition, the cabinet is properly sealed, etc. The tweeters might have ferrofluid that has gone bad.
The S45's are generally regarded as a nicely voiced speaker. If you don't like the sound of a well restored speaker, by all means hack away. But keep in mind that it is pretty hard to improve upon a well designed speaker.
What specifically do you not like about the speakers?
Glitch
Glitch
Anyone ever thought -or tried out modding any of their speakers? I have these Beovox S45-2 ones and I do like the imaging but feel like the tweeter driver could be replaced with a better one.Why?MartinBecause I've compared it with other speakers and found the tweeters of other speakers be a bit better
I don't know if the S45's use ferrofluid (FF) in the tweeters. Hopefully someone else can comment on this. The only way I know of checking if the FF has gone bad is to take the driver apart. I would only do this if I knew for sure that the driver had FF and the driver was sounding dull and lifeless. The FF should be a clear brown viscous oil. The viscosity can vary depending on what the manufacturer used. Bad FF can be muddy or even crusty looking. I only have one pair of B&O speakers left in my collection. They are Penta2's. Originally, I thought that they were somewhat dull and lacking impact compared to the other speakers that I own. However, the midrange seemed to do something special. I ended up making a bunch of modifications including changing the tweeter FF to one that was less viscous and modifying the crossovers to remove the tilted down" signature. I like them enough now that I can't imagine re-homing them. If you can describe what you find lacking with your S45's it will be easier for people to make suggestions for modifications. GlitchIt’s not that I don’t like it, but like I stated above, I feel like it could be improved over, also how can I check wherever the ferrofluid is still good?
What other speakers did you compare to?
Did you replace the capacitors or are the still the original?
S45 speaker sound pretty good if technic is ok. Little bit oldfashioned, not very clear, but pretty ok.
The crossover is made with bipolar electrolyth caps. Even new, the sound is just ok, not more.
Replace them with this material: Audyn MKS foil caps. They last or a lifetime... and the sound is superior for tweeters and crossovers. Just a little bit expensive...
https://www.google.de/search?sxsrf=APwXEdfKhAIQpbUCQv3JuWa-7OZkPReTWg:1682927688386&q=audyn+mks+kondensator+hifi&tbm=isch&sa=X&ved=2ahUKEwi6yrGY0tP-AhXySfEDHTOxAKIQ0pQJegQIBRAB&biw=2752&bih=1011&dpr=1.25
What other speakers did you compare to? Did you replace the capacitors or are the still the original? Martin
Wharfdale Evo 4.2 and Kali 8-In 2nd Wave. As far as I know the caps the the originals
-and the sound is superior for tweeters and crossovers. Just a little bit expensive… https://www.google.de/search?sxsrf=APwXEdfKhAIQpbUCQv3JuWa-7OZkPReTWg:1682927688386&q=audyn+mks+kondensator+hifi&tbm=isch&sa=X&ved=2ahUKEwi6yrGY0tP-AhXySfEDHTOxAKIQ0pQJegQIBRAB&biw=2752&bih=1011&dpr=1.25Just to clarify: Do you mean it sounds superior once that condensator is installed?
So, basically, you are comparing a 45 year old speaker still running on its original
capacitors that, ideally, should've been replaced 20 years ago, to two speaker models
that are currently available new in shops - and you find them lacking a little treble?
Well... replace the capacitors to grant it just a hint of fairness.
Kits are readily available.
Beovox S45-2 is an incredibly well balanced and sounding speaker, but it is not "audiophile" and will never be.
Keep in mind it was merely somewhere in the middle of the Beovox model range at the time.
That Philips tweeter was very good. It was used in many great speakers, including Philips’s own legendary MFB active speakers. I agree that replacing the Xover caps should be tried, hoping that the units were not damaged.
No ferrofluid was used by Philips, by the way.
Jacques
Jacques
Jacques
