iPod to B&O System Recommendations
Have you tried to connect to the Aux connection of the BS3200?
Craig🙂
If you have one of the latest versions of the ccdb installed in the BS-1 (4.7 j or k) then you could consider using one of Apple's AV/Universal docks to connect the iPod using STB or V. Aux connections. This will also allow you to operate the iPod from the Beo4, and see video on screen. You'll need an ir-flasher of course.
Or you could just make sure that the iPod's volume isn't maxed out.
Russ
I have not tried the aux input on the 3200 because I do not have that cable.
How do i check to see what ccdb I have installed on the BS1? I would like to use the remote if possible. How is the quality with this way?
Thanks!
The audio quality is as good as the encoding of your music. It can be bad, or in my case almost always pretty ok. Most of my music is mp3 at 320. Video is another story - not ready for primetime (bandwith issues). I tried three different ipod docks with my Avant (DLO, AR, Apple). When AppleTV came out, I switched and I find this is the best solution.
I do not have the latest ccdb on my Avant, so I use a Lintronic to control the docks and ATV. Not as simple as the ccdb, but it works.
With IpodTouch 2.0 I can now control the ATV easily from anywhere in the house with full two-way info that include album covers. Pretty cool!
Also connect IR blaster into IR input of SAT on BS1. Latest software of BS1 will enable you control Apple TV.
Scroll through available units of your BS1 menu (external sources) if apple TV is listed there you are in luck.
1. If you go to BeoSound menu - external sources
Highlight STB and scroll through available units. I believe if you have it it should be listed as Apple Remote.
I'm not sure what was the first SW version of BS1 that introduced it.
2. BeoSound 1 has only one set of component inputs. if your setup requires additional units to be connected you will need to use Zektor Switch. I believe Zektor was coded into BS1 ccd from version 4.7a
To verify if you BS1 is zektor compatible, go to your external sources menu. You should see last item in the list - SWITCH with only two available options NONE and ZEKTOR
I have version 4.7i on the BS1 so I do not see an apple remote.
I will get the zektor switch. Thank you.
