Help with AV9000
Singapore is PAL B/G - I didn't think the AV9000 made it to the US. Where did it come from? It may simply be set to the incorrect type of PAL which allows picture but you will get the incorrect sound.
Go to where the tuning is and go to tune a programme and you will see the third box has a letter in it. This will be the system used by the TV. You can change this by using the up and down buttons on your remote. You need it to show B/G. The other options can be M which is NTSC, L which is SECAM L and I which is PAL I. Just had a quick play with mine which will do I, B/G and L. The types vary depending on which type of AV9000 you have!
Best of luck!
Hi Peter, I brought my AV9000 from Singapore. At the back of the TV is a switch which says PAL / NTSC. I tried both but it didn't make any difference.
During the tuning, I can either select B/G or L, but both seem to work the same. The TV will search for a channel and when it stabilizes, it will go to B/G and I will only get static.
There are a few other switches behind which read Frequency 559-639, Attenuator On/off. Record Level, NTSC Pal 4.43 60 Hz.
I have tried fiddling with all but they don't seem to make a difference.
Any other suggestions? Thanks so much for the responses so far. I really appreciate them.
Please connect the cable box on the AV instead of using the tuner. TV will automatically detect the ntsc settings.Its NTSC on av socket only.
Faisal
