Connecting AUX source to Beo Ouverture
Hello! I just visited your website and had a question. I have a beolab6000 connected to a Beosound Ouverture. I was trying to connect an external network adapter for AirPlay and Bluetooth. I bought a Wiim Mini, and a 7pin to rca cable. I connected the aux out on the wiim mini to the ouverture with the 7pin adapter and no sound comes out the speakers. If I try to put the Wiim directly on one of the speaker and set it on « Line » It works. Do you have any solution for me? I wanted to have everything connected through the beosound ouverture.
Hi and welcome to Beoworld!
You need to make sure that your DIN to RCA connector sends the input to pins 3&5 of the DIN connector. Your lead is probably a DIN output using pins 1&4. (EDIT: You don't need a 7-pin DIN, a 5-pin DIN will work)
The correct connections are as follows:
Login to view image
EDIT: And make sure that you connect to the AUX input of the Ouverture and not one of the Powerlink sockets!
Login to view image
If you prefer to buy one….
….you’ll need something like
