Hey everyone, got an annoying issue with my recently acquired a BV4-50, roughly 5yrs old, which from what I can make out is a MkII (correct me if I am wrong) and a BS1. Anyone know from the numbers what Series the panel is D7 or D8 I'm guessing?
BeoSystem 1 BeoVision 4 - 50 MkII
Type - 8480 Type - 8951
Item - 1800403 Item - 1895126
SW - 4.7
Manufactured - Sep 2003
US BOX Service menu
Version
- BOX 4.7 May 26, 2004, built Wed May 26 17:12:11 FDT 2004
- MCAD Id:17, Ver:1, Rev:29, PROM:3d
- CCDB 4.7g
I will be bring the BS1 in to get the code converter database updated if applicable and understand that it's a good idea to get the chips updated while I'm at it if they aren't yet, I have seen v5.1 to be the latest for the chips.
Final got around to setting it up today and this is what I have so far... DirecTV HD H20-100 via component cables to the DTV IN on the Top Connection panel and the analogue sound R/L connected to the relevant sockets in the STB area on the rear connection panel. Then my Sony DVD player connected to the relevant sockets in the DVD area on the rear connection panel via S-Video and analogue sound R/L. STB External Source is set to DIRECTV H10 only option listed next to DIRECTV R10. BS1 is connected via the PROJ OUT on the top connection panel to the BV4's PC IN port as well as the BV4's RS-232C connected to the Data port on the rear of the BS1.
When the system is powered on the IR signal is sent to the BV4, it powers on and the sound fades in on the speaker but the picture is black. If you check the status on the BV4 it shows that it came up in RGB. When I switch PC input the picture appears. When the BS1 is powered off the curtain closes and sound fades out and the BV4 goes into Standby. I should add that in the setup menu the BV4 is set as Component/RGB-IN Select set to RGB. Regardless switching it to COMPONENT the same thing happens, it keeps defaulting to RGB Input on power up. Don't see any other settings even in the Service menu for the BV4.
Is there something that I am missing somewhere in the setup?
PROJ./SCREEN SETUP
PROJ./SCREEN 0
DELAY (SEC) 10
CONTROL/DATA 560
I have tried 555/557/560 as well as swapping the Proj./Screen and Control/Data settings, but nothing seems to work. And putting the 555/557/560 as the Proj./Screen setting doesn't put the BV4 into Standby, when the BS shuts off, the BV4 stay on, plus you get no curtain that I recall on shut down. So I am guess that 555/557/560 which all yield the same result need to be in the Control/Data setting where they were initial.
Can anyone shed any light!
Hiller
