I purchased a Beotalk 1200 on eBay. It arrived without any cables, adaptor, etc. I bought everything I need to connect the Beotalk 1200 from the B&O store in Toronto. I have downloaded the Instruction manual.
I have connected the beotalk as shown in the manual, however, it will not power up. I would like to be positive that it does not work before I return it to the seller. Does it need to be reset somehow? Are there any tips other than the trouble-shooting listed in the manual? Is there anything that I should do that is easily missed? Any tips or suggestions will be greatly appreciated.
Thank you,
John
