Beosund 3200
I have a real dumb question. Can i connect my beosound to an amp using the powerlink cable and then use some technic speakers that i have connected to the amp. I can't find cheap active B & O speakers. Please help
The answer is probably.
There is a sister site called
Beolab 2500 wil cost you about 300 euro's. An other alternative is Philips motion feedback speakers these works very well on the PL of Beo products
There is a German company called DeToma. They make amplifiers with a Powerlink input socket and standard speaker terminals. Then you can use any passive loudspeaker you like.
Ofcourse you can also try and find a secondhand B&O MCL 2P amplifier.
