How can I know if a beosound 3000 is compatible with masterlink ?
By the serial number or by another way ?
Thank you.
Eric.
You can connect a BS-4, 3000,3200, 9000 and a BC-2 with a PC-2/Beoport (is the same!)with a ML cable.... you have to ADD n-music and N-radio to you Beo-4 remote controle. Do you know how to do this??
Always thought that earlier BS3000's needed a Software upgrade for use with PC2.
Craigπ
If you press the 2 buttons list and Standby (with the rd dot) together you get the information Add on the screen, then you press βGOβ
Then press list until you see N-music and press βGOβ again, now N-music is add on your list!
The same you can do to add N-Radio to the beo-4!!
Register to access the forums, reference material, and exclusive member benefits β including our monthly prize draw.
