Beosound 3000
Hi everybody,
How can I know if a beosound 3000 is compatible with masterlink ?
By the serial number or by another way ?
Thank you.
Eric.
All beosound 3000's have ML
Ok, so they are all compatible with the beolink PC 2 ?
Yes they, a PC-2 has also ML connection and it works......... had it myself!!!
Thank you for the anwser πŸ‘ Eduard , I had a doubt  about it . Now it's OK πŸ™‚
Best regards,
Eric.
You can connect a BS-4, 3000,3200, 9000 and a BC-2 with a PC-2/Beoport (is the same!)with a ML cable.... you have to ADD n-music and N-radio to you Beo-4 remote controle. Do you know how to do this??
Always thought that earlier BS3000's needed a Software upgrade for use with PC2.
Craig😁
Very early ones do....  Software 2.0 and up us N Music ready... after serial number 154 ... something.
No, I don't know how to do this πŸ˜• with the Beo 4.
If you press the 2 buttons list and Standby (with the rd dot) together you get the information Add on the screen, then you press β€œGO”
Then press list until you see N-music and press β€œGO” again, now N-music is add on your list!
The same you can do to add N-Radio to the beo-4!!
