Beocenter 2500 cd door not loading...
Before I start to open the whole thing up,  I'm wondering if this is on a separate motor?  Could it be a belt?  The doors (if I had any) do open and close.
Any ideas?
Guy
Yes, the door mechanism is operated by a separate motor.
Thank you Graham.   Is it connected directly to the cd door, or with a belt?
Guy
Hi Guy,
Why don't you get the service manual for the 2300/2500 as you are a gold member?
Carefully scanned by Peter... for you!
Maurice
Edit: And not scanned for me as I'm just a bronze member 👍
The door mechanism is motorized. The mechanism itself is attached to a push rod that handles the opening function.
There are a number of potential problems that can cause this:
1. The power supply feeding the door mechanism is burnt out.
2. The motor handling this function is burnt out. This usually occurs when the door belt starts to slip on these units. The limit switch for the doors don't engage when they should, and the motor runs longer than it should.
3. The motor controller board has a problem, due to #2 above.
You should get a set of doors installed to actually test the doors under normal load. The glides will appear to function properly, but that may be just an illusion since the normal load is not on the belt and the motor.
B&O should offer preventative maintenance on this sort of thing at some reasonable cost, when units get to be about 15-20 years old. Virtually every unit out there will start failing when the door belt is stretched too far, or the limit switch is not engaged properly.
