Beo 6 remote
I think the software has been delayed for the moment - B&O were not completely happy with it just yet. having seen it in action, it will be well worth waiting for.
Since it will be using WiFi for communicating, the original BeoSound 5 will need a ML Gateway in the network somewhere.
I know next to nothing about ML so someone correct me if I'm wrong.
I was told yesterday by my dealer that they had receievd the software update for both the beosound 5 and beo 6 and now have 2 way communication on the beo 6. Ron
Has anybody seen the two way on the Beo 6 functioning?
It's not here in the US yet.... if a dealer has it working they are most likely testing it for the company... one would think the Chicago store would def. have it first as they are so close to the headquarters in the US. Look more towards the arrival of the Encore for the B6 wifi to be activated.... which shouldn't be too long here :)
and no you don't need the ML gateway for two way to work on B6, just a BeoMaster 5 and the B6.
