Colin
Does your 9500 play ok on channel two with the sub still hooked up? Mine does, But I want to make sure its not my sub that some how took out the right channel. How long did you run the sub before you had a proublum?
Mike
Colin
Mike
The mute relay commonly goes on one speaker as Peter says. Since the speakers play fine in the Skr2 sockets then I would stake my mortgage on the mute relay.
The mute relay, drive belts and strings for the doors, clip for the prop rod and battery are still available from your B&O dealer. The battery is situated near the remote sensor end of the microprocessor board.
The plastic channels are not available on their own as far as I know but new glasses come with the plastic in place.
You will have to find a helpful dealer who is willing to search the spares database as some of the part numbers are no longer available but have been replaced by others.
Graham
I lubed the railes to the cd door real good. With the lid open the door slides open and closed but wen I close the top and try it the door barly moves. I have the screws in the bottem set in the transport position. Is there a trick I'm missing? It acts like its hung up on the cd gizmo(the one that goes on top of the cd)
Thanks again
sorry to be such a pain
Mike
The door will not work well with the screws in the transport position. You are quite correct about it being hung up on the disc clamper mechanism. Take the screws out and it should work fine!
What did you use to lube the rails?
Silicone on a Qtip just like you said. Theirs white lube on the cd mechinisim looks old and dry. Should I clean it off? If so what should I replace it with?
Mike
Graham
HELP!!!!!!!!!!!!!!!! I removed the trasport screws and still nuthing. If I tip the front of the lid up the door opens and closes with the lid all the way down no go. I'm soooooo close to being done. What am I doing wrong!
Thanks again
Mike
The cd tray must be empty and the cd door CLOSED before you close the "hood".
That's all I can think of!
