I'm in need of some advise. I just got my beocenter 9500 off e-bay. Its got some proublums I was not aware of when I bought it.
1. Nether one of the sliding doors work but I can hear the motor run. The tape door tries to open but seems to be jamed on the bottem right corner. The cd door I got to slide open but now wont close.
2. Wen I first cnected the speakers every thing was ok. The next morning I had no right channel, I moved both speaker plugs in the back to speaker #2 and now it works fine agan. I am running a sub on the same line as the speakers. Is this a proublum?
3. The top & bottom glass pannels came loose in shipping. Luckly nither of them broke. But the plastic frame they sit in did. I have them sitting on them in place and everything seems to be working. Do you think I should fix this?
All this said it looks real good and sounds good. I'm pretty mechincaly inclined. Are theis repairs I could handle or best left to the pros? If b&o handle these any idea what in might cost? How do I get it to b&o, Ship from my house or do I hafto drop it off at the dealer?
All help and advise is welcome
thanks
Mike
