A new B&O owner (beocenter 9500)
I'm in need of some advise.  I just got my beocenter 9500 off e-bay.  Its got some proublums I was not aware of when I bought it.
1. Nether one of the sliding doors work but I can hear the motor run.  The tape door tries to open but seems to be jamed on the bottem right corner.  The cd door I got to slide open but now wont close.
2. Wen I first cnected the speakers every thing was ok.  The next morning I had no right channel, I moved both speaker plugs in the back to speaker #2 and now it works fine agan.  I am running a sub on the same line as the speakers.  Is this a proublum?
3. The top & bottom glass pannels came loose in shipping.  Luckly nither of them broke.  But the plastic frame they sit in did.  I have them sitting on them in place and everything seems to be working.  Do you think I should fix this?
All this said it looks real good and sounds good.  I'm pretty mechincaly inclined.  Are theis repairs I could handle or best left to the pros?  If b&o handle these any idea what in might cost?  How do I get it to b&o, Ship from my house or do I hafto drop it off at the dealer?
All help and advise is welcome
thanks
Mike
Hi Mike & welcome to Beoworld🙂
1. It sounds as though the cords which open & close the lids have come off the pulleys or the mechanism need freeing. Really quite difficult to work on if you don't know what you're doing. Graham our resident expert on these beocenters (member joeyboygolf) will confirm this and will probably give you better advice than me although it will probably require a service centre attention if you aren't well up on these. If you are confident however then I would strongly advise downloading the service manual which is available for download to silver & gold members, it's huge and in 4 parts I believe. Gold membership also automatically enters you for the monthly
hi,
have been thru the cord re-stringing... uggh... but not terrible. patience is the most important tool.
i would suggest ensuring that the doors move freely prior to re-stringing. over time, the tracks tend to lose their lube and then become sluggish. human reaction is to "aid" them along causing the cords to eventually pop.
so... chk the tracks, clean, straighten, lube, and make sure all is healthy before jumping into the timely re-stringing.
btw, the manuals have a graphic of the correct cord routing if both of yours have popped.
one last note: the operation is relatively delicate and smooth. it should work w/o any interference -make sure the tabs that ride in the slots are straight and true. -when all is right -the movement will be like butter.
welcome to beoworld and have fun w/ an excellent piece!
Thanks for the advise guys.  I know you said prices verry but do you think we are talking $100's or $1000's in repair costs?
Mike
I would say $100's rather than $1000's.
Chris.
agreed...
except your item #2 (mine was fine)...
i did have to deal w/ #1 and #3, and they cost me US$0.00 -just my time and patience.
i was able to source a nos lower glass panel (mine was cracked) for about US$100.00 shipped to my door.
again, well worth investing in this unit -hopefully #2 works out for you.
Jeff
You said you have done the door thing.  Any pointers,tips or dont let this happen to you?  I have looked at the manual and it looks like something I might try.  What should I use to lube the tracks?
Thanks again
Mike
Mike, any update on your amplifier issue? One of the two channels on my 9500 seems to have failed this week after several years of excellent performance. I, too, am running the output to a subwoofer that then passes on to the satellites. I wondered if it was a wiring option or s sub problem so I ran every possible iteration with the same result -- full sound from only one channel. Oddly, though, there is enough leakage that the subwoofer picks up some signal no matter which of the four powered outputs is used.
 As I'm 5 hours' drive from the nearest service center I'm looking at one channel for the foreseeable future. Or maybe just buying some penta's and bypassing the amplifier stage altogether...?
Thanks, Colin
i seem to have missed the beginning of this thread somehow. My apologies!
For info that I gave re lubrication see this
Graham
           I just got your anser on the channel one problum, Thanks.  Would the mute relay only go bad on the right speeker?  Because the left one will play and mute fine.  Both speekers play fine on channel two.
Do you know were I can get parts?  I cant find any one on line.  Parts like the drive belts for the doors, The  plastic channels that the glass pannels sit in, A clip for the prop rod and a batery wile I'm in there.  The batery still works but what the heck who knows how old it is.  Buy the way, Do you know wear it is?
Thanks again for all your help
Mike
