Hi all,
We are back from our travels and found the new 4500 system waiting for us. The units are superb cosmetically. The receiver sounds great and seems to function in all ways save one. It does not seem to respond to any of the remote control units. I have tried the Beolink 1000, the audio terminal and a Beomaster 5500. The 4500 does not respond to any of them. Is there a switch or setting somewhere on the 4500 that enables remote operation or some combination of buttons required to make it respond to remote commands? If not, what is the most likely cause of a failure to respond to the remote? The second issue is the common issue of apparently needing to replace the belts on the Beocord 4500. Martin, if you are following this post, can you PM the cost and availability of the belts for this unit. Thanks. It does rewind and fast forward but is really slow on play resulting in a wobble to the sound. I appreciate any suggestions on the remote issue. Thanks.
Jerry
