2 B&O system setup in one room?
Seems like noone can help me on the german forum, so I'll try it here...
I plan to upgrade my B&O stuff in my living room and add a Beocenter 2 to my existing stuff (BS9000 masterlinked to a BV7-40 with full 5.1 setup)
Is it possible to operate all 3 systems in one room with a Beo 4 / 5 (both present).
Removing the BS9000 is not an option, as I simply love it :-)
I just cannot figure out how to option set the machines so they all can be remote controlled in one room ??? 🙁
Thx for you replies
Stephan
I suggest you download and install the PCG (Product Configuration Guide) from here:
Strange piece of software... it seems it doesn't accept 2 audio systems in the same room ????
Question, has you BV7-40 got a DVD player, or a Bluray player, or no player at all?
p.
Note that in the software, you do not add the DVD2 as an audio product, but as a DVD player, after you've added the TV.
I got this result, but you need to refine this as I did not know which version of BV you've got:
************************* VIDEO SYSTEM SETUP **************************
BeoVision 7 - 40"MKIII TV
DVD 2 (VR 1)
Connection Video
Please note: BeoLab 7-2 must be connected to "Power Link Centre"
(not "Cinema Centre"!).
Display 1-2 (DVI-D out).
Connector for screen or projector.
A screen is connected to Display 1 and projector must be connected to Display 2.
HDMI-IN (A-D) (High Definition Multimedia Interface).
The HDMI sockets can be connected to any HDMI video source or PC.
Please note:
You can view 2 HDMI sources at the same time.
IR IN.
Connect the receiver cable to the IR-socket and plug it into the
6-pin terminal block of the IR-eye.
IR1+2.
The socket is used to check the IR-signal to the projector.
AV1 - AV6.
AV1 is used for AV connection of equipment such as a DVD recorder, VCR, HDR or
set-top box. (V MEM). 2-way communication from TV to product connected. AVL.
AV2 is used for AV connection of additional equipment such as a
digital satellite receiver (DTV).
1-way communication from TV to the product connected. AVL.
AV3 is used for AV connection of additional equipment such as a DVD player.
AV4 is used for AV connection of additional equipment. 1-way communication
AV5 is used for AV connection of additional equipment such as BeoMedia or a PC.
AV6 is used for AV connection of additional equipment such as a camera.
Connect the aerial to the aerial input of the VR 1.
Connect the aerial output of the VR 1 to the aerial input of the
TV-set using a coaxial cable.
Speaker.
Connecting speakers is made in the Power Link sockets.
 Speakers is connected to the Power Link sockets as single or
pair. If pair a Power Link splitter is required.
  In TV the centre speaker is connected to the (centre) socket.
If extra centre speaker is to be connected, a Power Link splitter is required.
Selecting option on the TV-set
Option programming with Beo5:
Option programming is made with the Beo5 Configuration Tool.
Options settings are sent to the products by means of the Setup menu in Beo5
Option: OPTION 2, with Beo4
                Press:                          | Display:
                STANDBY + LIST at the same time | OPTION?
                GO                              | V.OPT
                2                               | Observe confirmation
                                                | from BeoVision
Note!
It is not possible to connect an extra plasma screen to the TV.
If the VTR modulator frequency interferes with other signals in the
UHF range, adjust the modulator frequency by means of the screw
on the rear panel of the VTR.
The recommended distance between channels in the UHF range is
16 MHz.
************************* AUDIO SYSTEM SETUP **************************
BeoSound 9000
Connection Audio
Connect the aerial to the aerial input of the audio master.
Selecting option on the audio master
Option: OPTION 0, with Beo4
                Press:                          | Display:
                GO                              | V.OPT
                LIST                            | A.OPT
                0                               | Observe confirmation
                                                | from AudioMaster
********************* AUDIO/VIDEO/LINK SYSTEM SETUP *******************
Connection
Connect the Master Link socket of the audiomaster to the MASTER LINK
socket of the TV-set using a BeoLink cable.
********************* REMOTE CONTROL FOR MAIN ROOM ********************
The recommended remote control is Beo5
The following remote controls may also be used:
Beo4
 Setup for Beo5 remote control:
Programming Beo5 to operate products, Option programming and
zones, is done with the Beo5 Configuration Tool.
Hey Phil,
its the TV only version of the BV7-40 without any drive.
Best
Stephan
I realised when reading the setup instruction from the PCG that it does not tell you how to configure the BC2.
I have seen a few thread in the past on how to get both working in the same room, but although a few people said it can be done, nobody has said how.
I wouldn't buy it until I am sure it can be done.
I'd ask my dealer - after all, if he wants your money, he can investigate - and I would insist to see it working in the shop, before signing a big cheque.
My
My guess is that you could set it as Option 0 (the BC2), and not connect it on the Masterlink, it would work as a DVD player only.
Make that two then, cos I have one also.
Phil, will let you know tomorrow.  I'm just wiring the same configuration.  I'm phoning the dealer for advice.  You won't be able to use the DAB/CD functions on the BC2 though.  It's an expensive option for a DVD player, but the look is fantastic.
I have that setup. Few points:
- There is a software upgrade for the BS9000 available that you can use BC2 and BS9000 in the same room. I think that update lets the BS9000 be setup as a "link" product.
- I don't have that update but switched the BS9000 to option 0 so that it doesn't react to the remote. I connected it to the line in of the BC2. TO play single CDs I use the BC, if I want the random play or want to play multiple in a row I use the BS9000.
I noticed that besides volume I rarely use the remote when listening to music .....
Cheers
JK
P.s. The software was discontinued by B&O I believe so it's not up to date anymore
P.P.s 2 Audio Master in the same room are generally not possible in the B&O world. BS9000 and BC2 seem to be an exception
