I have being using Avant 32  as master in my linksystem. Have been working very well.
No I have installet a BV7 And I have change it to be the master. But as I understand it is not possibly to use both with modulator   The problem is that I have only 2 line in AVANT menu so I can´t switch it off.
1=TV LIST
2=SETUP
Is there any way of reset  and start all over again.
Also what should the BO4 be programmed with   LINK ????
It is only the Video signal that is missing. Radio, CD .. works ok.
My set up is  BV7 (master) AVANT32 , BL2000, BS4500, BL3500, BM1, MX4000
BV7 have STB decoder Motorola VIP1903  Works ok.
Need info who to set all up.
