Beovox 80.2 how to repair front grill mount.?
  Hi.....:-) Do you have any advice on how to repair these nobs..
https://archivedforum.beoworld.org/forums/t/42609.aspx This is a excellent guide ...But the only problem is getting the blu wall plug...
Find a wall plug correct diameter and cut length to size, glue on with good epoxy.             Clean and even base before gluing
Retired Printing machine technician Restored various 1960-70 items Rock and Roll music Collecting Vinyl Restored Jukebox Wurlitzer 1050
Thanks..But i am looking for a better solution
Do you have the broken off pieces?
No I don't
I made copy pegs in my lathe, leveled the base, the pegs made with bigger "foot" and glued them to the base, will go and look for the speaker in my dungeon, if found I will post a pick
