Hi B&O fans,
this is a little guide how to test and repair this magnificent VX5000 video and audio deck. I think, it was besides the VX7000 the most advanced and highest evolution of all video recorders. 12kg high tech in a small cabinet, very stylish ... and very complicated.
The VX5000 is a pretty old machine today, most of them are over 20 years old and have a lot of bigger and smaller defects. All have problems, i have had a lot of them (several hundred...) and 99% could be repaired.
I was asked to rework this article because many of the pictures were lost.
OK, first the defects which you can see on the tv.
1.) Noisy Picture with horizontal bars, sometimes distortions, black and white horizontal bars
The capstan motor is defect.... and the power supply.
2.) Sometimes very strong humming sound, shutdown after some minutes or it's impossible to load or unload the tape
The capstan motor is defect, yes...
3.) It is impossible to load unload the tape, the loading unit is broken
The capstan motor is defect, yes, again...
4.) the internal tuner shows bars, noisy picture, the sound is dull or just a grey/black picture
The tuner unit is defect.
5.) the recorder is dead, just the display shows 0000, no further reaction
power supply defect, fuse blown, probably capstan used until dead...
6.) recorder is working, but the sound is missing, speed is not ok.
There is a small mechanical part broken or missing near the audio heads.
7.) lost time, forgotten adjustments, strange behaviour, slow or no operation when connected to mains
Lithium cell defect
8.) defect tension arm (on the left side of the drive), collision with tape guide unit
Missing part, lost spring, broken part, misalignment
9.) The VX goes into "STOP" mode without any reason
The capstan motor is defect, power supply defect, 12V regulator unit defect, lower mainboard regulator unit defect, defect caps
10.) some more? Tell me ;)
Defects 1-3: The defect Capstan Motor:
Noisy and distorted picture: this has nothing to do with the cylinder head, cleaning the heads will not solve the problem. The VX5000 cylinder head is one of the very best heads ever used, it shows almost no wear even after 20 years, even heavy use shows almost no wear. I had only 2 defect heads until now... and they were mechanically killed by a cleaning attack by the user...
So, DO NOT CLEAN THE HEADS! That's not necessary and just a risk to damage them.
The capstan motor is responsible for the constant tape transport, winding slow and fast, reversing and for loading the tape.
This ist the capstan motor.
This motor is 90% responsible for all defects. It is a 3-phase motor with a variable speed and has a tacho unit. So this part is real hightech... and expensive. The last price for this motor was around 110 Euro, i dont know wether it is still available or not.
But it can be repaired. 🙂 at least around 80% of them... if necessary, i still have some new and used in working condition.
There are 4 silver capacitors on this motor, smd parts. 1x 3,3uf , 1x47uf , 2 x 22uf . These capacitors dont like age and heat. And they become hot, the board is steel and cooling unit at the same time. SMD parts like these have a lifetime of around 1000 hours on permanent use, not longer. If they go defect, they loose electrolyt and the board becomes black around the caps.
The motor runs now without control, uses to much current and becomes hot, really veeeeery hot... you will burn your fingers especially when you touch the chip.
Exchange the 4 caps, it's really easy. Dont use a solderiron, just use a plier and turn them around... dont pull, just turn. Then clean the contacts on the board with new solder, wash it with some hot water and bathroom cleaner. Disassemble before cleaning the motor axle (just push it through, watch the small plastic washer...) and the plastic cover. Dry it and oil it a little bit when assembled. Clean the axle afterwards.
I dont use smd parts here, just normal 105 degree caps so it's pretty easy.
The capstan is located here. Just open the black metal cover on the underside of the VX, just 7 bolts. Watch for the small noses on the front cover, dont break them off.
The motor itself is mounted with 3 bolts and a fourth one for the power transistor. Just pull off the cable and disassemble the motor. Thats really easy.
This is a close up of the caps. You see the black dirt around the caps? The copper has turned from green to black, it's oxide. This motor is completely dead and will become very hot... let's see wether it becomes a second life.
This is the backside, even zinc plated steel gets corrosion problems with the acid electrolyt.
Disassemble the motor this way...
Now remove the four caps with a plier, just turn them around. they will break off without a damage to the board. But do not pull, just turn! Clean the contacts with solder and with paint thinner, then wash it.
Wash the unit with hot water and a bathroom cleaner. Mainboards can be washed, that's really no problem, i have washed already complete tv sets. The only thing is, how to get them dry again... and very fast.The only problem is, that steelparts can corrode if water stays inside. This one is small enough, dry it with a hairdryer.
But it becomes clean as new.
Here it is already completed with new caps. All you need is:
2x 22uf 25V (original 35V)
1x 47uf 16V (original 6.3V)
1x 3,3uf 16V (original 50V)
Minus is the black bar on the smd parts.
Some more details...
Finished, the motor should now be working again. Assemble it to the VX, load a tape and test it. If load works, reversing and the chip does not become hot, then it's ok for the next 10 years. If you used 105degree caps, you will not repair it again in your life.
The VX5000 has a self test program and some test modes. So you can test the motor, the drive and the general function of the VX.
LED test:
Press "HQ OFF" on the front keys and at the same time connect the VX to the mains. After 10 seconds release "HQ OFF", then press it again. All leds and indicators will now light up in a sequence.
RAM/ROM test:
Press "HQ OFF" on the front keys and at the same time connect the VX to the mains. After 10 seconds release "HQ OFF", then press ">>". On the screen you will see ... maybe you must press "VTAPE" on the Beolink 1000...
VX5000
Version x.xx
Datestamp
Rom PASS
Int Ram PASS
Ext Ram PASS
Drive test:
Load a tape before test. Disconnect mains. Press "SOUND" on the front keys and at the same time connect the VX to the mains. When the VX starts to play, release the button. Press VTAPE on your Beolink 1000 to see status messages.
It will play, rewind, record and play again and eject the tape. If everything is ok, it will go into standby. If something is wrong, it will show "FAIL" on the display.
All tests are ended by disconnecting mains.
