Which DIN cable?
I managed to snag a pair of S80s. I haven't received them yet, but I hear they only have a DIN socket.
Is this correct? If so, is it the 2-pin type?
Also, what gauge wire can I use with 2-pin DIN? I think I'll just buy the plug from my local electronics store and solder it to some hifi wire.
Yes they are the standard 2 pin DIN fitting as on most B&O speakers.
Any decent speaker wire will be just fine, don't try for anything too thick as it will cause problems when soldering the plugs. I have known strands of wire inside the plug body to become free and cause problems with shorting.
Chris.
