When paired to TV-box, Beovision is in black & white
Hi all, I'm using
Any ideas? Thanks
If I recall correctly there's not much you can do. I had the same issue with a BV ME6000 when I bought my first bluray player. Changed the televisions for a MX6000 which handles both PAL/NTSC. There was no way to change on the player.
Not sure but for the macbook you might be able to change the output.
Thanks for your answer.
If anyone has ideas as to what I can do about my macbook being displayed in black & white on my Beovision, let me know!
Thanks for your help.
