That letraset stuff is expensive! At least the custom transfer stuff which I would need for the bottom images...
Other question. Did you paint the panels or did you tape them over? either is suggested in your previous posts.
No you did not, I looked again and the painting was eugene. I got confused with you both making white panels in such different ways.
Yes, I am
Did I? link referred to adhesive tape so not painted!
I will need something like that or some other type of laminate to cover the speaker set I intend to match up. for smaller piece the paint is fine, but I wouldnt want to use it on a larger surface area like a speaker cabinet unless I sprayed it.
I have a set of S-75 with some pretty beat up woodwork that would be an ideal candidate for such a project.
I will need to do some "local" research to see if I can find something suitable.
Beautiful work on the Redline speakers (CX's too).
Leslie, can you share your technique on the Redline grill cloth replacement? Do you do it by yourself? I restored a pair of RL140 speakers last year and they came out very good. However, I finished those up thinking there has to be an easier way. My method took three people. I built some cardboard guides to allow me to spray adhesive (3M Super 77 I think) only to the areas I needed glue - the strap channels, the area where Bang & Olufsen is embossed and the rear area of the frame where the cloth attaches. After spraying the glue on I had a short amount of working time so two people kept the cloth taut while I place the frame down and wrapped the edges over and into position. I also had to make sure I pressed down the front side (strap channels and embossed lettering). I saw the other Beoworld post where two-sided tape was used on the rear of the frame. That looks like a good alternative. I would really like to know your steps and what kind of glue/tape you use. Also, what kind of grill cloth did you choose?
Thanks,
sonavor
