To answer both dillen and leslie's questions. It is the bottom plate of a beomaster 2200. It's nothing special. But I wanted to see what could be done for what cost and it seemed like the perfect candidate for an experiment. I have added two pictures that I think will show the difference.quite well. If you look closely you will see that the surface is not completely flat on the rust spots after powder coating. That is because the rust had eaten into the metal. This kind of thing most likely kan be repaired to if you really want to, but for something that is on the inside I choose not to investigate that.
Before, note the rust and peeling paint in the top and bottom right, these were not the only spots
Login to view image
after sand blasting and powder coating, same corner
Login to view image
Still need lettering and an arrow for the voltage selector. I've read several instructions on decals and silkscreening and the like, but I do not know what would work best. I'm in my first attempts at cleaning up "vintage" equipment. So tips on lettering are welcome
