Wanted module for Beolab Penta
For Beolab Penta I am looking for an input board (PCB module 22).
That's the one at the bottom of the amplifier with a metal bracket held by four screws to the main chassis, it also carries the sockets.
Martin, do you need Mk1 or Mk2/3 (without/with PowerLink)?
Lawrence
A mk1 doesn’t have the PCB22.
I’m sure I have 1 spare in my storage. I’m only able to enter that storage not sooner than next Thursday. Due to some renovations
there.
In which case I definitely don’t have a spare.
L
Sorry, it's for a Type 6631 (mk3), but I think mk2 (Type 6621) has the same board.
Beobuddy, if you have one, that would be great.
PCB22 are the same on both mk2 6621 and mk3, 6631. But the board where the sockets are soldered on are modified at the mk3. Where the mk1 and mk2 needs power on pin 1 and 4, has the mk3 board slightly modified by cutting a trace and bringing pin 1 and 4 together. The result is that the mk3 can de powered on with only pin 4.
Martin, I will search for one. Must have one here also.
Still looking.
Anybody?
As promised. I will look today for the module.
Will be this evening.
Found a mk2 chassis.
- And module 22?
