Wake up on LAN BV 12 / V1 & Commands
Hello,
I have a BLI and am able to send control and light commands to my BS4's & V1's however only when they are online. Before I used masterlink with cores and IR's and it worked perfectly. I have actually removed the IR eyes fromn the wall. Now it seems that the Beovision V1 needs to be at least awake in order to receive the commands. It meens If I want to open a window or a curtain I need to first start up the TV?
That is really annoying. Normally it would not have been a problem had I new than I would haved kept the IR eye on the core.
This is so dumb, any workaround? V1 is not bluetooth so I cannot program the BR1 with Buetooth it is either IR or Bluetooth. Does a speedup timer help?
Thanks Chucky
What are your energy settings? And which timers have you set? I believe here is a difference between “deep” sleep (BV offline) and “slumber mode” (BV online).
You nailed it thanks. I did kill all the energy settings but did not set quick start timers.
They now run from 6:30 till 23:59.
Thanks again, much appreciated!
Chucky
