I'm very interested in this setup!
I wondered if this would fit my needs. Maybe some advice would be welcome.
I'd like a good 4K TV/screen, I'm currently only looking to use it as a screen without sound/apps/whatnot. The main source would be a computer (probably a mac mini, maybe something windows/linux based if that allows better integration) running a kodi application for watching series and movies. In the future, I may start using Netflix too, but for now, I'm ok with my own personal content on the computer.
I want a 5.0/5.1 setup, using at least active speakers for the fronts (looking out for some used beolab 9s) and maybe also some lab 3s for the rears. (Currenly using an old amp and some Bose cubes. Replacing the rears would require upgraded cabling and power supply to be added in the ceiling.)
The speakers should be used for watching movies/series, but also for playing background music, preferably in sync with other airplay speakers in the house.
I currently have an older macbook pro running kodi and itunes, connected to my ancient LG tv. The computer is always on, and itunes is always running s.t. I can just press play on my iphone remote app for itunes. There is the old amp and the Bose speaker set. For watching series, I'm using 3 remotes (the horror!): power on the amp, power on the tv, and control the mac using an aluminium apple remote. For listening to music, I power on the amp and use the iphone to control the itunes on the macbook.
This setup works fine for now. Powering up an airplay speaker in the kitchen makes it automatically join the airplay music of the living room.
In the future (when a newer tv and a set of beolab 9s are joining the party), I'd like to get rid of all remotes but one, and if this one could be a beoremote one, that would be ideal!
I suppose I'll need a fancy amp/pre amp for connecting the speakers? Or can active speakers be connected to a mediacenter pc directly? (The main windows computer in the household has 5.1 3.5mm jack outputs for speakers... Or are beolabs not to be connected to such outputs?)
Now, would it be possible to have the beoremote one to control the kodi application on the computer, like: press TV on the remote and automatically power up the screen, (pre)amp+speakers, wake the computer and start the kodi app, after which arrows/play/pause/etc works on the kodi app?
Would it be possible to map a press on the MUSIC button to turn on the amp and speakers and start playing a specific playlist on itunes? Or, if the itunes part is impossible, simply just power up the amp and speakers s.t. I can press play (or choose different playlists) on my iphone remote app?
(Is there any way of choosing playlists on the remote, be it even as in selecting one of 3-4 sources which could correspond to my main 4 playlists? (i'm only ever using 4 specific lists and don't need their names on the remote, something simple like 'list1', 'list2' would already be enough!))
(Power everything off using the standby button on the remote should be possible I suppose?)
I guess most pre-amps nowadays have airplay support too, so the itunes computer could also be a separate unit that simply airplays to the (pre)amp and the other airplay speakers without intervention of the beoremote (but this would require speakers to be set to LINE IN, hence no automatic on/off trigger. Or maybe such a trigger can be engineered from a triggered output on the pre-amp?).
So, a lot of questions/advice needed. I am tech savvy (did computer science at uni), so a bit of programming is no problem. I have however no experience with raspberry pies or arduinos yet.
What hardware would I need to get my ideal system working?
About your setup: How is the CEC working? You are using a receiver to relay the CEC controls from the PI to the respective devices? Speakers are connected to the receiver?
Thanks a lot for the info and your input! I've only just discovered your post and it finally looked possible to achieve my ideal setup.
