I will disassemble and part out one (1) Beovox S80 with the usual faults: several of the dots on the speaker covers are disrupted, it has foam rot in the woofer and theres old capacitors in the filter.
On the other hand is speaker covers straight and good looking, except for two microscopic holes in the lower grill. The cabinett is also good-looking without too lot of wear. Tweeter and phase link is entirely okay, like the woofer - apart from the foam ring as mentioned.
The midrange phase link and the upper grill are gone.
Maybe the woofer and the other drivers fits to other speakers?
I can send from Sweden all over the world.
