Hi all
Does anyone have an update on the CD ripper issue where it does not work with long cable installations? My beosound 5 was installed without the ripper due to no stock, now there is stock BUT for a long while now the local dealer tells me there is a known problem with the ripper and it does not work correctly with the long cables - which mine has, so he will not install until it is resolved.
Anyone know better?
