I recently bought a B&O G505 LP portable gramophone, but I can't find any information on it anywhere.
Does anybody know something about this product, I assume it must be rare, but I would like to know more about it.
Yes, I noticed it too.
The gramophone deck was available as a separate unit, meant for building in to
another piece of furniture, your existing or something homemade.
Unless you can find some type/model plates or some other form of information
on the case, I suspect this is such a homemade case.
With the need for an amplifier and speaker - the gramophone deck can't do much
on its own - producing a portable unit like this would not appeal to many buyers.
Can you tell if an amplifier and maybe a speaker has been built in too ?
Hi Dillen,
I inspected it yesterday before I bought it later in the evening, there was some kind of room beneath the deck which was not accesible because of a broken hinge. I will pick it up tomorrow, and make a reply on what is hidden beneath the deck.
So the gramophone deck was available as a seperate unit ? - I have never before seen one of these, I guess the infomation is limited as I didn't find anything about it when I searched the net or through the great Bang&Olufsen book.
Nevertheless, the unit seems to be very similar to the one fitted in a a Master 506RG.
Vifa
I picked up the item today. The room beneath the deck only revealed two cords, the box itself must be homemade of some kind.
It is almost like a simplified cheap version of the Unitape 512K :-)
