So I'm struggling with several problems in a Beomaster 5500. In fact it is a gathering of scrap parts from other repairs, so all problems from other Beomaster 5500's are now collected in 1 chassis.
The first repair is done, the 8 volt power was gone but with replacing 2TR12 and repairing some print damage this is now working.
1 problem I have is that the tuner is not working.
If I select tuner on the MCP, the "A" symbol and the "radio" symbol is lighting on the chassis, and the MCP shows "150"
Then, if I press "turn" on the MCP, normally the tuner should switch to FM, but this doesn't happen.
The tuner board itself is not the problem, I changed this with a board in another chassis and it works.
The problem seems to be in the microcontroller.
Question is, is this something which can be "magically repaired" by pressing some keys, or is the microcontroller ready for the scrap bin?
