Hi, last week, I bought a Beocenter 7700 from 1986. This is also my first time writing in this forum. My Beocenter seems to be in very good condition except from one problem that I am hoping someone can help me with.
The problem: The pickup arm needs “extra” weight and also needs to be manually pressed down to work.
I have taped on a paperclip for some extra weight. It is still skipping. Then with a light tap on the tone arm / needle with my finger it "popps" down and stays in this position thru out the whole record, it doesn't skip and the music sounds great (at least in my ears)
The needle is sitting 3-4 mm over the LP (without any weight) before lowering down on to the record and then it is hopping/skipping (jumping).
The counter weight is turned to almost 1.5 It says in the manual it should be 1,2.
I am hoping for some advice,
Many thanks, Dan
