Timer recording on Tape2 possible (BM5000) ?
Just a quick question: is it possible to set timer recordings on Tape2 in Beomaster 5000 ? (Or BM5500, for that matter ?)
Can't figure out how to do it on MCP5000 and could't find answer in manuals nor searching the forum either...
- Jari
Doesn't it work as any other source (RECORD under the flap - TAPE2 - DAY - time - STORE...)? Direct recording to TAPE2 is a bit more complicated, but I don't believe there's anything special to it regarding timers.
Sorry, I wasn't clear enough. It is just timer recording TO tape2 that I'm asking. I suppose it is not possible at all...?
- Jari
Oh, you were clear enough - I wasn't thinking 😁
No, I don't think it's possible, except perhaps when the source is TAPE1 - that could make some sense if it's something else than a tape recorder.
Timer recording to TAPE2 is possible on BS6500. On that, you select CONTROL-TAPE2 before the rest of the programming sequence. I don't believe it works on the 5000 as it's not mentioned in the manuals, but worth a try I guess...
Tried it; not working on BM5000!
Just have to live with it...
- Jari
