Why?
I was not into HIFI or had done any experiences that way. I was into guitars, effects and amps sounding right but not the stereo or video department.
In my case it was really not planned that it had to be B&O but in a matter of 3 weeks that changed for good. I got the '80s Beosystem 2000 and an B&O Attyca II stand for it. That was the beginning and I just got a palisander Beocord 9000 a few months before.
Getting into the old school B&O experience that way was cool. Once the many units were serviced the feeling of how right the B&O products were at any given time they deserved to live on for another 20 odd years of great experience for the owner. Be it sound, feling, looks or the technical matter like certain speakers certain age. If you want passive then post '90s unless its CX you want or want to play records or cassete tape? The same thing applies. Sentimential reassons? No with B&O pick the design you want. It will perform well in any case.
B&O to expensive? Well if it is then why bother. Expense of anything is a matter of what you think you can achieve. If it is to expensive it is.
I even have even managed Beolab 6000 and 8000 so far.
Old stuff sounds better?
It sounds good but you neeed to compare it and I had Beosound 9000 at some point. It is not that different.
I grew up with record and cassete tapes with cd comming much later. Why should I change mediums for being able to play music every 10 years or so? Music on pc? Right but that takes to many changes for no real good reasons at all. It depends on what mediums you prefer.
It does not really get better. The grass is not more green with the newer B&O.
Would I go for it? Yes Beovision wise but streaming of music I don't plan to do.
Futuristic
I don't get tired of the sound, looks or the space it takes.
