I quote Jon:
As far as I understand it to be, Bang and Olufsen decided on using the filler-driver concept as a way to compensate for the phase shift introduced by a crossover.
Because of the resultant phase shift with a crossover, the driver's polarities usually are reversed so that their acoustic output sums flat at the crossover point. This, however, obviously means the speaker system can never achieve a minimum phase response (zero phase shift being the goal).
What B&O did with the 3-way Uniphase speakers is to design a crossover with symmetrical 2nd order low-pass and high-pass acoustic slopes, but with the drivers connected in phase. Then, in order to counteract the resulting cancellation in response, they used a midrange driver to "fill in" the response - that midrange driver's passband being centered in the middle of the high and low frequency driver's crossover point. Above and below it's passband, the midrange driver's acoustic response rolled off at a shallower rate. This meant that the overall frequency response of the speaker summed flat, yet the drivers were all in phase with each other.
As well, B&O "time-aligned" (physically lined up) the acoustic centers of each respective driver. This is why you see some of the drivers a bit more recessed on the baffle than others. So, the Uniphase designs are "transient-perfect" as well, in that they can (mostly) accurately reproduce a square wave. Notice that "time-aligned" designs which are not also either minimum phase (zero phase shift), or linear phase (the entire passband of the speaker phase-shifted by an equal amount), are not transient perfect.
I believe the 2-way Uniphase speakers have the response of the high-pass and low-pass sections overlapped, and then the hump in response is tuned out.
There are WAY more knowledgeable people than I who discuss this at length. You can probably Google things like "transient perfect" and "filler driver" and find alot of useful, in-depth information. Search for a man named "John Kreskovsky" - he's written a few papers about this subject.
The merits of this design are highly debated, with many people saying you'll never hear the difference. I'm the kind of person that doesn't always trust my ear, but I do believe what I can measure to be true. Within certain limitations, I believe in the merits of these designs.
Many people claim that due to the reflections and phase anomolies introduced just by your listening room, a transient perfect design is a moot point, and I can see where they're coming from.
Also, by nature, these designs have poor vertical polar response, illustrated perfectly by the big difference in sound quality you get when you listen standing up versus sitting down. Even if you could somehow get around the room influences, the Uniphase speakers' transient perfect quality (and really, it would be the same with ANY similar design, not just B&O's) would be evident only through a very narrow listening window. Move up or down off axis out of that listening window, and that phase coherency is lost.
These speakers were made back when B&O was more concerned with technical perfection, IMO. It's not an easy thing to do; what they did, that is. It resulted in a more complex and expensive design, but one they considered worth it. Again, many doubt the validity of these designs in the first place, and don't even bother to acheive these design goals. And I've heard many fine speakers that are nowhere near transient perfect in nature. But there are a number of manufacturers that do strive for this, so I guess it just depends on what you choose to believe.
