/SOLVED/ Is it a B&O product?
Dear fiends,
I found these speakers for sale and seller is claiming, that this is Bang Olufsen product. Is it?
Thanks for advice.
[View:http://elektro.bazos.sk/inzerat/51409022/REPROSUSTAVA-BANG-OLUFSEN.php:800:0]
No, definitely it is not a B&O pruduct.
What a hideous thought!  Not a chance it's B&O.  The bottom bits of the stands look a lot like the bottom sections of the 'Trumpet stands' but that's it.
Dave.
They look very much like some Grundig Audiorama model on the short table stand, but the band around the actual speaker should be horizontal. I suspect these are some no-name design ripoff.
After some googling, they seem to be ITT Korona speakers from 1976:
To me they look like ITT Korona:
Thanks for yuor help.
