(SOLVED) Century Glass Door does not close
Hi everyone
I just got a century in from a friend that does not play CD, the motor was not spinning at all, it was an easy fix as it was just bad solder.
So I started the unit for general check and the doors close and then open and do not close anymore.
The clamp is OK, I cleaned everything and placed new grease everywhere, so must be electronic.
Anyone had this already ???
It's not the clamp!
There are 3 sensors you need to clean:
1. At the gearbox, there's a little PCB, held by one screw, loosen it, clean the sensor on the pcb. Then clean the gear wheel below with a qtip touched in some cleaning fluid. Turn the gear wheel manually clockwise around and clean it so the sensor is able to tell the difference between the white gear wheel and the black fields on the fear wheel.
2. Unscrew the 4 screws around the CD player cover and remove the whole cover. There's a sensor on the right hand side on top. Clean that one as well.
3. Below the right speaker fret, in the middle of the main PCB there are the last two sensors, two diodes, make sure there's no dust on them as well.
Also, don't forget to clean the Perspex part of the speaker frets so the 2 diodes that you just cleaned in step 3 can see through the Perspex
Dear Root
Thanks, did all what you said (nothing)
I even exchanged the 2 sensors from another Century (same parts numbers), nothing, nothing.
I am checking in the diagrams on PCB 9-5-3 page 2-17 of service manual but there is not much to check
1 Capacitor and then comes the microprocessor
so I think I will have to check the microprocessor, if someone feels I am looking too far please feel free to post 😕
Since the door open and closes once when I plug in the power cord, must be a problem in the timer and I suppose its in the processor
P83C528
32kx8 ROM
5 | 2x8 RAM
uPR0CESS0R
PS: What type of sensor is the one of the gear box ???
Check fuses & poewer supply to sensor receiver, transmitter, & motor control.
Hi
While checking the voltage on the sensor receiver it suddenly closed the mechanism (the century is kind of nude, no window anymore), Tried to find where was the problem but was not really able to find it.
I just resoldered the 3 wire plug on both side and until now it keeps closing the mechanism.
I did not get how it works, as usually the sensors are hidden. How does the sensor detect the hand ???
To make it work I have to move the sensor receiver aways and when turning it back to the unit it opens the mechanism.
Drives me crazy that door thing.
When you place the sensor (PCB20- receiver)  in its location the door does not close nor open.
When you place the sensor out of its location upside down doors are opening and closing normally when passing hand above the sensor.
Could it be a problem inside the wires ??? like cut somewhere !!!
I can post pictures if it can help
Might be the wire or the sensor.
Hi Bos00
I will go nuts with that door thing
Changed with a known working sensor, no change
Checked cable continuity OK
Checked voltage 5.0 Volt at sensor between ground and brown wire, 0.600 between the ground and the white wire.
Fooling around created another problem no more 5 volts at sensor, had to change a 10 ohms R, that is the one that changes 5.2 volts to 5.0 volts
Does the same symptom with the working sensor of another century
Keeps working upside down and once inserted it its place : NOTHING ..... 🙁
Did not find the crying smiley but could use it !!!!!
Hi everyone
Back to the door thing
Did more testing the doors are working when radio is on.
But if I press CD and when the CD does not get recognized the doors stays open.
So the problem is with the CD, but why can it work sometimes a whole day and suddenly I cannot start it anymore.
Bad contact Somewhere ???
Are the doors related with the CD ???
I believe they are related if I remember correctly. They use the same motor for the CD clamper and the sliding glass door. I don't know if this is of any help in this case though.
